CarPro Reset - Intensive Car Shampoo
+15
fuento
alessio86
Cek
L0r3nz0rm
17hamsik
ORSO
pincio
rustico
19 partecipanti
Vai alla pagina : 1, 2, 3, 4, 5  Successivo
1CarPro Reset - Intensive Car Shampoo Empty CarPro Reset - Intensive Car Shampoo Mer 19 Feb 2014 - 14:49
CarPro Reset - Intensive Car Shampoo Reset-logo
Chi sarà mai questo sconosciuto,non ci sono foto del prodotto ma solo la descrizione sul sito ufficiale...Antonio!!!!!!pensaci tu!
CarPro Reset was formulated as the perfect partner to nanotechnology based sealants and coatings, with cleaning properties tailored to their unique needs. Utilizing Intelligent pH Surfactants, Reset breaks down road grime and traffic films with the power of an alkaline cleaner, whilst being as gentle on the surface as a pH-neutral shampoo. Afterwards Reset quickly rinses free from the surface, leaving behind no soap residues or interfering silicones, and restoring the beading and dirt releasing properties (The ‘Hydrophobic Effect’) of the surface to help maintain its protection. Combined with excellent lubrication, a strong foaming action for improved dirt suspension, and a high dilution ratio, this makes for a highly effective and economical wash. At the same time, Reset is almost entirely based upon naturally occurring, organic ingredients, making it as safe for the environment and for the user as it is for the vehicle. If dirt is hiding the beauty of your car or motorcycle, then you know that it is time for a Reset!
Features & Specifications
Developed for use with all CarPro Nanotechnology Sealants and Coatings including Reload, Hydro2, and CQuartz.*
Intelligent pH Surfactants provide a strong cleaning and foaming action, whilst remaining mild and pH-Neutral (7) in use.
Derived almost entirely from natural, organic and biodegradable ingredients; free from the harsh sodium and lauryl sulfate derivatives found in many shampoo products.
1:500 Dilution ratio allows for very economical cleaning.
Excellent lubrication and delicious smelling Watermelon scent make for a safe, and enjoyable wash experience.
Can be used as Snow foam shampoo as well.
Application Instructions
Step 1 – Fill wash bucket with 15-20 liters (Approximately 4 - 5 gallons) of water, adding 30-40 milliliters (Approximately 1-1.35 ounces) of Reset as the bucket fills to mix the shampoo solution and activate the foam. Use warm water for maximum cleaning power.
Step 2 – Pre-rinse vehicle with free flowing water to remove loose debris, and wash out of direct sunlight from the top down using a CarPro Swirl-Free Wool Wash Mitt or Wash Sponge, rinsing the mitt/sponge periodically in a second bucket filled with clear water.
Step 3 – Do not allow shampoo to dry on surface! After washing, rinse the vehicle thoroughly with free flowing water to remove shampoo residue, and dry with a soft Microfiber drying towel or forced-air blower.
Step 4 – If necessary, use CarPro Spotless to remove hard water spots, and apply either Reload or Hydro2 to top-up the vehicle’s protection.
*May degrade weak organic waxes and polymer sealants.
Note: In case of sensitive skin or a pre-existing skin condition, wear protective gloves whilst washing to avoid possible dryness and mild irritation. This applies to all cleaning products.
In poche parole lo shampoo dedicato per i nano carpro Smile
Lo scrivo in neretto altrimenti poi si finisce li:
*May degrade weak organic waxes and polymer sealants. (SI decera  Laughing  )
E' uno shampoo, tosto e con l'obiettivo di pulire. Sono curioso di provare la versione definitiva che è in arrivo tra 15 giorni e confrontarla con il meglio dell'attuale offerta. E comunque non va a neutralizzare una protezione in modo diverso da un White Schiuma Wink
rustico
rustico
Come dovrebbe collocarsi? Sembrerebbe uno shampoo forte come il 2g con la sicurezza di un 4g... Sarebbe fenomenale!  cheers
Sarebbe ma non è: è molto più simile al White Wink
pincio
pincio
Magari da usare come prelavaggio accoppiato alla tec4....
E' uno shampoo non un prelavaggio! Miii ragazzi non cominciamo a fare confusione anche con questo altrimenti non ne usciamo più!  affraid  Laughing
rustico
rustico
Ahahahah siamo delfini curiOOOsi Very Happy
Attendiamo gli esiti dei test allora Smile
pincio
pincio
Pardon... Embarassed
ORSO
ORSO
Quindi uno shampoo aggressivo?
Scusate ragazzi, ma considerando che con un (o più) prelavaggio adeguato uno sporco anche rilevante va via facilmente... Uno shampoo aggressivo ha altrouso oltre quello di eliminare la protezione?
10CarPro Reset - Intensive Car Shampoo Empty Re: CarPro Reset - Intensive Car Shampoo Gio 20 Feb 2014 - 16:42
Non è più aggressivo di un White Schiuma. Il concetto si collega un po' a quello che avevo scritto qualche settimana fa in un post dedicata al mantenimento dei nano coatings: non è tanto importante il mantenimento con sealant spray ecc.. quanto un lavaggio corretto. Wink
11CarPro Reset - Intensive Car Shampoo Empty Re: CarPro Reset - Intensive Car Shampoo Dom 30 Mar 2014 - 23:28
Testato questo weekend,10 ml su un secchio con circa 6 litri d'acqua, mi è piaciuto molto,non pensavo lubrificasse tanto siccome bastano pochissimi ml,di solito ero abituato ai 40 del daytona Smile
Potere pulente ottimo, a pelle dire sopra al 4g però servirebbero più test.
12CarPro Reset - Intensive Car Shampoo Empty Re: CarPro Reset - Intensive Car Shampoo Lun 31 Mar 2014 - 16:57
ORSO
ORSO
Lo devo provare. Magari come alternativa al BTBM... è più potente no?
Ha lucidanti? Dalla scheda sembrerebbe di no
13CarPro Reset - Intensive Car Shampoo Empty Re: CarPro Reset - Intensive Car Shampoo Lun 31 Mar 2014 - 18:13
17hamsik
17hamsik
batfed ha scritto:Testato questo weekend,10 ml su un secchio con circa 6 litri d'acqua, mi è piaciuto molto,non pensavo lubrificasse tanto siccome bastano pochissimi ml,di solito ero abituato ai 40 del daytona Smile
se soddifatto da una diluizione 600:1 direi che è uno schampoo sconvogente e non può mancare.
14CarPro Reset - Intensive Car Shampoo Empty Re: CarPro Reset - Intensive Car Shampoo Lun 31 Mar 2014 - 18:19
davvero un bel shampoo! ottimo car pro!
CarPro Reset - Intensive Car Shampoo Logo_l10
15CarPro Reset - Intensive Car Shampoo Empty Re: CarPro Reset - Intensive Car Shampoo Lun 31 Mar 2014 - 18:39
Vero! La schiuma è bestiale... Penso che possa dare qualche soddisfazione anche in foam visto il potere pulente...
ORSO
ORSO
In situazioni di sporco tosto può risultare utile
rustico
rustico
In effetti lo vedo OTTIMO come prelavaggio su un´auto trattata con un nano per poi passare i soliti W1, 4g, btbm e compagnia bella...
L0r3nz0rm
L0r3nz0rm
E uno shampoo vero e proprio !!!!
Direi che e tutto molto chiaro ph ottimo ( nano come cq uk vengono intaccati da shampoo alkalino con ph >11 . Quindi studiato per prodotti car pro )) utilizzabile anche a snow foam ))
rustico
rustico
rustico ha scritto:In effetti lo vedo OTTIMO come prelavaggio su un´auto trattata con un nano per poi passare i soliti W1, 4g, btbm e compagnia bella...
Mi sono perso un "anche" tra "ottimo" e "come"  clown
ORSO
ORSO
Ma con tanti prodotti appositi perchè andare a foammare uno shampoo?! Invece io lo devo tenere per quando lo porco è più tosto e il BTBM anche più concentrato fatica un po'... Questo inverno mi è capitato
pig pig pig il reset quando lo porco è più tosto è fenomenale!!!  pig pig pig lol! lol!
rustico
rustico
Mi spiego meglio: come prewash su EXO uso in genere o 4g o W1 nella TEC, ma spesso non danno i risultati sperati (quasi inefficaci quando piove fuliggine), Reset mi ispira piu putenz, rimanendo comunque delicato...
Poi magari sto dicendo un sacco di cagate rimanendo sulla mia posizione ma il forum c´e´ anche per questo  Laughing
Se non danno risultati in prewash White Schiuma e GWash (ed è normale essendo shampoo), non lo darà nemmeno Reset.
Sono shampoo non prewash!
rustico
rustico
Non vorrei sporcare ulteriormente la discussione, chiudo OT Smile
ORSO
ORSO
L'iPad ogni tanto si salta qualche lettera Very Happy
Comunque, tornando on topic, questo reset lo devo provare... Magari prendo il campioncino che con la smart ogni confezione "normale" è una fornitura infinita Smile
Torna in alto  Messaggio [Pagina 1 di 5]
