Aquartz Clean Air
+5
Cquartz
9 partecipanti
1Aquartz Clean Air Empty Aquartz Clean Air Gio 29 Lug 2010 - 16:27
Mr. Aquarz,
please, can you explain something about use, application and advantages of Clean Air.
For me it's very very interesting Nanotechnology application's to clean air inside our cars.
Regards
A Sicilian boy....!!! Very Happy
http://www.amatodetailing.it
2Aquartz Clean Air Empty Re: Aquartz Clean Air Gio 29 Lug 2010 - 18:04
domanda trasmessa... arriva Avi!
3Aquartz Clean Air Empty Re: Aquartz Clean Air Gio 29 Lug 2010 - 18:40
Cquartz
Cquartz
Hi
CleanAir is nano based photo catalyst coat,
titanium oxide reaction with daylight and air.
it kills all bad smell, viruses, germs, bacteria ..etc.. you have on area where applied,
this technology used already in hospitals , public toilette's, and others.
for the best information i think Antonio should translate the tech info at my website about CleanAir
http://www.aquartz.net/cleanair.html
application is very easy, spray all over the interior of the car, on plastyics , spray and wipe off,
open windows for 30 min, finito!!
4Aquartz Clean Air Empty Re: Aquartz Clean Air Gio 29 Lug 2010 - 19:14
yes Avi... in fact all the information are in the shop Wink
I think that Simone wants know others secrets and particular advice of this product...
5Aquartz Clean Air Empty Re: Aquartz Clean Air Ven 30 Lug 2010 - 0:24
Yes, my question was to know other particulars about this product.
The information that Antonio translate for us are perfect and detailed.
How many quantity of Clean Air we need to sanitize air?
If Do we spray inside clima air, the product does't work because missing the sunlight action
or can we activate Clean Air in a different way?
6Aquartz Clean Air Empty Re: Aquartz Clean Air Ven 30 Lug 2010 - 6:21
Cquartz
Cquartz
average car complete interior will be 100ml , the consumer bottle we sell is 120ml, there is option to buy in 1L bottle too.
the CleanAir works with daylight, not necessary sunlight !!
it can react with fluorescent light also !
any more questions, let me know
7Aquartz Clean Air Empty Re: Aquartz Clean Air Ven 30 Lug 2010 - 9:43
OK Avi, only another question:
I want to sanitize pollen filter. So...I'll clean it a little with just air an a microfiber...than...when it will be clean, I'll spray on your Clean Air...and than...for example with your head lamp, and I will be my pollen filter like new...Tell me if this concept is corrected...!!!
Thanks AVI
always a Sicilian Boy...!!! Very Happy
8Aquartz Clean Air Empty Re: Aquartz Clean Air Ven 30 Lug 2010 - 9:52
Cquartz
Cquartz
what is pollen filter?? the air condition filter?
just clean it with air pressure , spray the CA on ,,let dry , thats it
9Aquartz Clean Air Empty Re: Aquartz Clean Air Ven 30 Lug 2010 - 9:55
Perfect AVI...!!!
10Aquartz Clean Air Empty Re: Aquartz Clean Air Ven 30 Lug 2010 - 10:01
Cquartz
Cquartz
post your results ,so other guys here will understand what we are talking about
such product is hard to show thru videos Very Happy
11Aquartz Clean Air Empty Re: Aquartz Clean Air Ven 30 Lug 2010 - 10:34
Ci farete un riassunto poi? Very Happy
12Aquartz Clean Air Empty Re: Aquartz Clean Air Ven 30 Lug 2010 - 12:07
Traduzione (riassunto delle ultime puntate )
Avi dice che per trattare un' auto intera con clean air sono necessari 100 ml di prodotto (quindi praticamente un' intera bottiglia da 120 ml) la luce del giorno e'suff. per far reagire il prodotto e non e' necessaria la luce solare . Il prodotto reagisce anche con la luce fluorescente . Per trattare il filtro antipolline Avi consiglia di pulirlo con aria compressa , spruzzare clean air , lasciarlo asciugare e il gioco e' fatto .
Aquartz Clean Air Wm_28010
13Aquartz Clean Air Empty Re: Aquartz Clean Air Ven 30 Lug 2010 - 12:13
Il Clean Air è un prodotto nanotecnologico basato sulla Fotocatalisi: il biossido di titanio reagisce con la luce del giorno e con l'aria, eliminando cattivi odori, germi, batteri, virus. Solitamente è una tecnologia utilizzata per sanificare i luoghi pubblici come ospedali, bagni pubblici ed altro.
Allora ho chiesto qualche chiarimento in più circa la quantità del prodotto da utilizzare all'interno di una vettura.
Avi risponde circa 100 ml e dice che è possibile comprare anche le bocce da 1 litro.
Allora gli chiedo se può essere utilizzato all'interno delel bocchette dell'aria condizionata anche se non arriva la luce del sole.
Lui risponde che non è importante la luce solare, ma la luce del giorno. Praticamente anche con una lampadina fluorescente si attiva il processo di fotocatalisi.
Successivamente ho richiesto se potevo utilizzare il Clean Air per igienizzare il filtro dell'aria.
Mi ha risposto che basta soffiare il filtro con aria ed applicare il Clean Air.
Mi ha chiesto di postare successivamente i miei risultati inerenti all'utilizzo di questo prodotto perchè è difficile mostrarlo in video.
14Aquartz Clean Air Empty Re: Aquartz Clean Air Ven 30 Lug 2010 - 15:08
Sembra un prodotto tanto innovativo, quanto fenomenale
15Aquartz Clean Air Empty Re: Aquartz Clean Air Ven 30 Lug 2010 - 15:13
Infatti, mi attira molto il suo funzionamento...!!!
16Aquartz Clean Air Empty Re: Aquartz Clean Air Ven 30 Lug 2010 - 15:16
Cquartz
Cquartz
small important thing !!
If use cloth just to remove dust on the surface, cleanair will last longer than 6 months.
2. If use cloth with dust remover/cleaner, clean air will need to coat again – shorter than 6 months. But catalyst effect last longer than 6 months.
17Aquartz Clean Air Empty Re: Aquartz Clean Air Ven 30 Lug 2010 - 15:18
Fleterik
Fleterik
s.amato ha scritto: Successivamente ho richiesto se potevo utilizzare il Clean Air per igienizzare il filtro dell'aria.
Intendi il filtro aria dell'abitacolo?
18Aquartz Clean Air Empty Re: Aquartz Clean Air Ven 30 Lug 2010 - 15:23
Ad averlo saputo prima lo inserivo nell'ultimo ordine....mi rode sentirne parlare e non poterlo provare direttamente Very Happy
19Aquartz Clean Air Empty Re: Aquartz Clean Air Ven 30 Lug 2010 - 15:30
SI
20Aquartz Clean Air Empty Re: Aquartz Clean Air Ven 30 Lug 2010 - 15:43
Fleterik
Fleterik
SI
Ahhhh....OTTIMO!!!!
21Aquartz Clean Air Empty Re: Aquartz Clean Air Mar 3 Ago 2010 - 16:57
semplice e geniale!
22Aquartz Clean Air Empty Re: Aquartz Clean Air Mar 3 Ago 2010 - 17:18
Infatto Sabato faccio il tagliando alla macchina e proverò a pulirlo con il Clean Air...che genialata...uauauauauauau!!!
23Aquartz Clean Air Empty Re: Aquartz Clean Air Mar 3 Ago 2010 - 18:38
mi raccomando al resoconto! Very Happy
24Aquartz Clean Air Empty Re: Aquartz Clean Air Gio 5 Ago 2010 - 10:16
Ostello
Ostello
Ottimo questo prodotto.
Ma fatemi capire bene, basta spruzzarlo negli interni della macchina(dopo una bella puliza con D101 ecc..)ed il gioco è fatto?
25Aquartz Clean Air Empty Re: Aquartz Clean Air Gio 5 Ago 2010 - 16:07
come indicato nell'inserzione il prodotto si spruzza, si stende con un panno ed il gioco è fatto. Wink
